Receiving MIDI Program Change messages (PC)
Incoming MIDI Program Change messages are used for navigating through Presets, Banks, and Setlists on Quad Cortex.
We will use CC#32 (value 0-12) for changing Setlists. Up to 12 custom Setlists can be stored in Quad Cortex:
- Factory Folder (Setlist 0)
- My Presets (Setlist 1)
- Setlist 2
- Setlist 3
- Setlist 4
- Setlist 5
- Setlist 6
- Setlist 7
- Setlist 8
- Setlist 9
- Setlist 10
- Setlist 11
- Setlist 12
CC#0 will be used for splitting up the Setlists into groups of 128 Presets:
- CC#0 value 0 is used for Presets 0-127.
- CC#0 value 1 is used for Presets 128-256.
Example #1
If you want to load the Quad Cortex Preset 129 (17A) in Setlist 5, then you would send the following PC message to the unit:
CC#0 value 1, CC#32 value 5, Program #1
Example #2
If you want to load the Quad Cortex Preset 68 (9D) in Setlist 9, then you would send the following PC message to the unit:
CC#0 value 0, CC#32 value 9, Program #67
The last CC#0 value will be remembered until the user changes the CC#0 value again and chooses to load a Preset from a different preset group.
MIDI Reserved PC List (Banks 1-16)
MIDI Reserved PC List (Banks 17-32)
Receiving MIDI Continuous Controller messages (CC)
CC messages can be used for the following purposes:
- Change modes.
- Scene changes.
- Tap tempo BPM.
- Enable/Bypass footswitches A-H.
- Open/Close Gig View.
- Open/Close the Tuner.
MIDI Reserved CC List
